https://www.samsung.com/us/computing/monitors/curved/34--cf791-wqhd-monitor-lc34f791wqnxza/#support
Hi. This is the type of computer monitor that I have. I am looking for a way that I can mount it to the wall.
Samsung has this on their website:
https://www.samsung.com/us/support/answer/ANS00039995/
I am confused how I would attach it to the wall, though, as I do not see any place for screws on the back of the computer. Help!!!
https://linustechtips.com/topic/857169-help-me-find-a-wall-mount/
So that FAQ only applies to 6 different types of monitors that they sell, sadly the one you have is not one of the ones supported, hence why you don't see the VESA mounting screw holes
Project Hephaestus
Intel Core i5 6600K @ 4.2GHz~ASUS Maximus 9 Hero~32GB DDR4 @ 3200MHz~ZOTAC GTX 980 AMP Ed.
Well, the manual at page 17 suggest that there should be a wall mounting bracket shipped with the monitor:
http://downloadcenter.samsung.com/content/UM/201701/20170119103231707/BN46-00559A-Eng.pdf
You can attach it where normally the stand would be attached. After that you are still needing a VESA wall mount to mount the monitor with bracket to that...
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
