I am using a H115i in a Enthoo Pro M Special edition black/white. Where should I place the rad? I was thinking the top and having the fans as exhaust but then I would get negative air flow as I would have 2 intakes and 3 exhausts. However if I place it in the front I would have to deal with the RAD being slightly lower which I don't think will look great and the Halo fan rings wont shrine through the case. Where would you guys put the rad?
Side note, this is going to be the build: https://uk.pcpartpicker.com/list/CMmXjc
What colour cables would you run? I am thinking black/blue or white/blue but i am unsure. Thanks
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/857157-aio-positioning/
Jayztwocents did a video on it, you can actually keep the pressure neutral. You just have to adjust the fan RPM to make it match
Frostbite (White build PC)
MSI B350M Mortar Arctic - Ryzen 5 1600 @ 3.9 GHz - Corsair H60 - ASUS GTX 1060 3GB DUAL OC @ (2130 MHz Core Clock + 4600 MHz Mem Clock)
2x8GB 3200MHz Corsair Vengeance C16 Corsair 400C White - EVGA 650 GQ
  Razer Deathadder Chroma - Razer Blackwidow Tournament Edition Chroma - Sennheiser HD 598 SR - LG 24MP59G-P
https://linustechtips.com/topic/857157-aio-positioning/#findComment-10671874
very true. although you still wanna probably make it front intake because it will be louder to make 2 front (im assuming two for the front.) stronger than 3 exhaust.
Retrowave
Air cooled version of my first PC.
CPU: Intel Core i7-8700K
Cooler: Corsair H150i PRO
Thermal Compound: Thermal Grizzly Kryonaut Thermal Paste
Motherboard: Asus ROG MAXIMUS X HERO (WI-FI AC)
RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3600 Memory
SSD: Samsung 960 Pro 512Gb M.2-2280 Solid State Drive
SSD 2: Samsung 970 EVO Plus 1TB M.2-2280 Solid State Drive
HDD: WD Black 6TB 3.5" 7200RPM Internal Hard Drive
HDD 2: Seagate Barracuda PRO 4TB 3.5" 7200RPM Internal Hard Drive
GPU: EVGA GeForce GTX 1080 Ti FTW3
Case: LIAN LI O11 Dynamic XL
PSU: EVGA SuperNOVA P2 1000W 80+ Platinum Fully-Modular ATX Power Supply
Case Fans: Corsair LL120
Fan Controller: Corsair Commander Pro
Set Up
  • Mouse: Razer Deathadder Elite
  • Keyboard: Razer Blackwidow X Chroma
  • Mousepad: Steelseries QcK Gaming Mousepad
  • Monitor: Asus ROG Swift PG278QR
  • Audio
    • AMP: Sennheiser GSX1000
    • Headphones: Sennheiser 58X
    • Speakers: Bose Companion 2 Series III
  • Oculus Rift + Touch 3 Sensor Roomscale Setup
https://linustechtips.com/topic/857157-aio-positioning/#findComment-10672405
