Hello, i have this problem that almost every game i play like for example GTA 5, my gpu doesn't go above 60% load. I have 65-80 fps all on max 1080p. I was thinking it may be a bottleneck from my cpu (i7 3770k). But alsof those 4 cores aren't fully loaded( 40-60% ).Anyone here that knows what the problem is? I also have a 1000W Corsair psu, 16 gb 1600mhz Corsair ram 2x 2tb HDD and a SSD of 120gb.
Have a really big case with 2 fans and a decent cpu cooler.
Thanks in advance.
https://linustechtips.com/topic/855256-not-max-load-on-1080ti/
gta v is CPU intensive, so I guess so, possibly, but it's good enough for most other games, assuming you have it overclocked.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/855256-not-max-load-on-1080ti/#findComment-10651294
Do you have a frame limiter or v-sync on? If so then it will cap the framerate and not use more than is needed.
Also look at individual thread usage on the CPU, not just overall usage. It's possible that the bottleneck is single-threaded and maxing out just one thread.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/855256-not-max-load-on-1080ti/#findComment-10651303
Nvidia Control Panel -> Manage 3D Settings -> Settings: -> Power Management Mode -> Prefer Maximum Performance
Windows Power Options -> High Performance
GTA V is very poorly optimized as as others have said it is probably a CPU bottleneck. What is your usage in a game like Overwatch, Battlefield or PUBG? They tend to use more of your GPU.
If you are not overclocking that CPU your are committing a Sin our lord and father GabeN. Every Ivybridge CPU can go to 4.5 Ghz on all cores.
https://linustechtips.com/topic/855256-not-max-load-on-1080ti/#findComment-10651405
