apple earplug ... they are quite trendy !
Server 1 PC                                                   Server 2 PC                                               GEAR
CPU: Ryzen 7 1700                                                   CPU: Athlon 200GE                                               Keyboard: Logitech G Pro Keyboard
Motherboard: Aorus AX-X370-K7                            Motherboard: Gigabyte GA-A320M-S2H              Mouse: Logitech G900
CPU Cooler: Wraith Spire RGB                                CPU Cooler: Stock Cooler                                    Mousepad : Corsair MM300
Ram: Kingston 32GB 2666MHz                                Ram: Patriot Signature Line 8GB 2666MHz          Monitor: Acer XZ350CU Black 35" 21:9 144 Hz
GPU: Gigabyte G1 Gaming 980ti                              HDD: 1X WD Red 2TB                                           Headphones : Audio technica ATH-AD700X
HDD: 5X Seagate Barracuda 7.2k RPM 1TB            SSD: 1X128GB Samsung Evo                              Speakers: Logitech Z506 5.1
SSD: 2X512GB Samsung Evo                                  PSU: EVGA 100-W1-0500-KR 500 W1
PSU: HGC 850W Antec 80+ Bronze                         Case: Rosewill 2U Server Chassis
Case: Rosewill 4U Server Chassis
12 minutes ago, OsuMasterz said:
My left channel of headphones broke so now I need new ones. I was looking at the Corsair Void Pro RGB, and the wireless and wired versions are the same price. Which one should I go for? Or you can suggest something different idc.
i switched from the corsair void hybrid to the steelseries arctis 5, i personally like the arctis much more, but the corsair void is a decent one as well, both corsair one's that you said are pretty good, but the rgb will drain the battery a lot. maybe look at the arctis 7
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
A little out of my price range, Is there anything competitive at max $80?
the hyperX cloud, cloud 2 or alpha are all good choices, the are the most bought gaming headsets
I guess the real question is, do you need wireless or not?
If not, then *cough cough shameless plug cough cough* a ModMic or similar "non-headset" solution will basically always be better dollar for dollar. e.g. A ModMic 4 and a Superlux 668 is ~80 USD. For a few dollars more (~$90-$100)  you could get the Philips SHP9500. For a few dollars more than that, Sennheiser 558 (which were 80 dollars last time I checked) or Sony MDR 7506 you can have basically an amazing headset that only cost you ~$130.
Of course none of that matters if you need wireless! Not yet at least ;)
There are other solutions than ours too of course. Plenty of mics in the sea!
Director of Marketing for Antlion Audio, creators of the ModMic.
More info at www.ModMic.com
Ask questions, I'm friendly!
