Hi,
I'm Looking to upgrade or build a new pc
The maybe upgrade one is a stock Dell XPS 630i but last year I trew out the Gpu's ( 2x Nvidia 9800Gt) and put in a HD 6950.
Dell Xps Specs:
Intel Core 2 Quad Q 8300, 2.333Mhz
Standard Dell Xps 630i Mobo
4Gb DDR2
AMD Radeon HD 6950
HDD 500GB + OCZ vertex 4 SSD
I was thinking of building:
Sabertooth Z77
Intel I5 3570k
Crosair vengeance 8Gb 1600Mhz ( The low profiles)
Corsair Ax 750 Watt Psu ( Maybe the new i series)
Ocz Vertex 4 SSD
Corsair Graphite 600T
H100i
If I build one I'm pulling the SSD out of my Dell and will put it in the build with the 2de (new) one :)
Any tips or advice are welcome :)
Thanks,
Michiel
Ps: If I wrote something wrong I'm not English :)
https://linustechtips.com/topic/855-first-build-or-upgrade/
I would recommend a MSI MPOWER Board. It's all black which you want, and is cheaper with the same features. Unless you love Asus, I would get that instead. I would also get an AX650 instead just because you don't NEED 750 watts for that system and you could save some money. Your choice though :) Another thing is the SSD. I'm not a fan of OCZ for SSDs. If you got a really good deal on it then go for it! But and M4 would be a better option. IMO. Don't think I'm making fun of your build, because trust me mine isn't any better! I'm just giving you suggestions :) Hope I helped.
https://linustechtips.com/topic/855-first-build-or-upgrade/#findComment-11018
I would recommend a MSI MPOWER Board. It's all black which you want' date=' and is cheaper with the same features. Unless you love Asus, I would get that instead. I would also get an AX650 instead just because you don't NEED 750 watts for that system and you could save some money. Your choice though :) Another thing is the SSD. I'm not a fan of OCZ for SSDs. If you got a really good deal on it then go for it! But and M4 would be a better option. IMO. Don't think I'm making fun of your build, because trust me mine isn't any better! I'm just giving you suggestions :) Hope I helped.[/quote']
I'll consider the Mobo suggestion :) I'm good with the Ocz ssd because I already got one in my old pc so thats why i'm buying the same ssd so I can pull the "old" one out :) and the 750 watts, I know myself and will probably put a 2nd gpu in it (once I got the money :p ) and some other stuff :p
On a side related note :p does anyone got a good idea what color of caselights I can put in a white 600T? :D
https://linustechtips.com/topic/855-first-build-or-upgrade/#findComment-14166
I would recommend a MSI MPOWER Board. It's all black which you want' date=' and is cheaper with the same features. Unless you love Asus, I would get that instead. I would also get an AX650 instead just because you don't NEED 750 watts for that system and you could save some money. Your choice though :) Another thing is the SSD. I'm not a fan of OCZ for SSDs. If you got a really good deal on it then go for it! But and M4 would be a better option. IMO. Don't think I'm making fun of your build, because trust me mine isn't any better! I'm just giving you suggestions :) Hope I helped.[/quote'] I'll consider the Mobo suggestion :) I'm good with the Ocz ssd because I already got one in my old pc so thats why i'm buying the same ssd so I can pull the "old" one out :) and the 750 watts, I know myself and will probably put a 2nd gpu in it (once I got the money :p ) and some other stuff :p On a side related note :p does anyone got a good idea what color of caselights I can put in a white 600T? :D
I have red leds in my white 600t..
but pure white looks amazing too!
and I have the sabertooth aswell, good board and the armor looks great imo, i know you pay for it though.. :)
(Comming soon)
https://linustechtips.com/topic/855-first-build-or-upgrade/#findComment-14186
  • 3 weeks later...
Does anyone know if this config is possible? It would all be 120mm fans. and i dont mind if it would have to be zip tied or with Velcro or something like that.
And one more question, would this be a good airflow config?
[ATTACH=CONFIG]n2638[/ATTACH]
https://linustechtips.com/topic/855-first-build-or-upgrade/#findComment-42353
Does anyone know if this config is possible? It would all be 120mm fans. and i dont mind if it would have to be zip tied or with Velcro or something like that. And one more question' date=' would this be a good airflow config? [ATTACH=CONFIG']n2638[/ATTACH]
The fan mounts aren't in the front for 120mm fans however you could do a bit of modification one would think. I'll let you know soon with a definite answer when mine turns up :P
https://linustechtips.com/topic/855-first-build-or-upgrade/#findComment-42498
