Wierd Graphical Issue
Go to solution Solved by m0k,
DDU and reinstall drivers from scratch?
which windows 10 version are you on?
So I'm not really sure where to put this exactly in the fourms so if a mod see's this and thinks theres a better spot feel free to put it in that section. But I've been having this issue that whenever I open a program like say Mincraft Launcher (Like shown in video) it almost pauses my screen and reverts back to a image from like I wanna say like when I first booted my PC. In the video you see it go to a image of osu! and that was when I literally just started my PC and opened it. Originally I thought maybe it was a issue with the latest GeForce driver but I updated and it didn't fix. So I'm not sure what to do with it now. So I thought I would ask you guys and see if you had any ideas. I'll link the video so you guys can see what I mean visually. Thanks for reading.
https://linustechtips.com/topic/854986-wierd-graphical-issue/
2 minutes ago, unkn0wn1 said:
you could try ddu or you could re-seat or put the video card in a different pcie slot which will reset all the settings. It kinda looks like a vram type issue which is strange.
My Board only has 1 PCIE slot. So I guess just try the ddu?
https://linustechtips.com/topic/854986-wierd-graphical-issue/#findComment-10648762
The DDU seems to have fixed it. Opened 5 programs that did it before and nothing. So hopefully it stays like that. Thanks both of you for your help!
https://linustechtips.com/topic/854986-wierd-graphical-issue/#findComment-10648885
