Hi there,
It might be a silly question but i want to buy a new case for my system, im looking to buy the coolermaster masterbox lite 5 RGB with 3 rgb fans included.
Now my motherboard has no rgb headers and also only 1 sys fan header, i think the case includes a splitter but then i still have no rgb, can i connect those fans to a separate rgb controller from china or is it made to only work with software?? Also what would be the alternatives if i still want lighted fans in the front of my case.
Thanks for reading :)
https://linustechtips.com/topic/853737-rgb-fan-help-needed/
1 hour ago, wONKEyeYEs said:
Are you sure?
The specs say...
"Pre-installed Fan(s)    Rear    120mm x 1 black fan"
http://www.coolermaster.com/case/mid-tower/masterbox-lite-5/
https://www.newegg.com/Product/Product.aspx?item=N82E16811119325\
RGB version my friend
If you want to argue with me, and you probably will please PM me, no need to ruin threads becase you dont like how I am.
Ask me how I made 100k selling illegal narcotics!
and you think im joking, Did a lot of wrong to get my money right.
I look up to Larry Hoover.
Your homies loyal 'til the one time you tell 'em no
https://linustechtips.com/topic/853737-rgb-fan-help-needed/#findComment-10634270
