Let's start out with my hardware list:
MOBO: Asus Z170-A
The problem part: Intel Ethernet Connection (2) I219-V integrated to the MOBO
CPU: Intel i5 6600K
GPU: GTX 1080
Windows 10 x64 version 1709
Now the problem:
I have recently gone through the trouble of wiring my computer to Ethernet instead of using my cheapo USB wireless card. For about an hour it was working just fine but out of the blue it disconnected and wouldn't read the connection unless I disconnected the cord and reconnected, but it would only stay connected for about one minute before doing the same thing. I have gone through the standard suite of troubleshooting: try a different cord, use a different LAN port, disconnect-reconnect, make sure that the latest driver is installed, uninstall and reinstall the drivers for the network adapter the Intel Ethernet Connection (2) I219-V but with no success. I have searched through the sub-threads and have seen a few others have been having similar issues with the same network adaptor. I have tried the solution found in the post here but it didn't work for me and the other posts have been unresolved. At this point in time, I am out of Ideas on what to do. If someone with more experience has any ideas, I'm willing to hear you out, and thanks in advance.
https://linustechtips.com/topic/853734-problems-connecting-to-ethernet/
MOBO: Asus Z170-A
CPU: Intel i5 6600K
GPU: GTX 1080
Now the problem:
Are you sure you don't have the same ISP that I do?  Suddenlink.
plug your computer into the router, and power cycle your modem, and router.
then go into cmd and type:
ipconfig /release
ipconfig /renew
ipconfig /flushdns
then reboot your computer
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
ipconfig /release
ipconfig /renew
ipconfig /flushdns
That didn’t do it either. Thanks for the suggestion though.
