Ethernet cable broken
Go to solution Solved by marten.aap2.0,
as long as none of the eight internal wires are damaged, you should be able to use it.
you said it is still working so I guess they aren't damaged, check it to be sure and then wrap it in tape
its fine, just wrap it with some electrical tape :)
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
https://linustechtips.com/topic/853397-ethernet-cable-broken/#findComment-10630267
 "Aeneas troianus est."
I'm allergic to social interaction in real life, don't talk to me in real life please.
don't forget to quote or tag (@marten.aap2.0) me when you reply!
https://linustechtips.com/topic/853397-ethernet-cable-broken/#findComment-10630270
