First Overclocking
Solved by WereCat,
Pascal cards can only change clocks by 12.5MHz at a time so you going from +160MHz to +155MHz did nothing, that's also why your clock is 2152MHz instead of 2139MHz.
Also, when the GPU temp goes up, the clocks will go down by about 12.5MHz-25MHz by about every 6°C-8°C.
More volts and power = higher temperature which may result in lower clocks.
5
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
