Looks fake as hell. The potato resolution doesn't help either.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/853339-leak/#findComment-10629656
Doesn't even have the NDA disclaimer on the bottom. Fake as all hell.
Main Rig:-
Server:-
https://linustechtips.com/topic/853339-leak/#findComment-10629670
I can't really read the text but 12 cores 24 threads for $329 sounds unrealistic to me since they have a 12 core part for $850  which would be a more than 50% price cut and with amd's current financial situation I just don't see them wrecking their profits that hard
https://linustechtips.com/topic/853339-leak/#findComment-10629691
IIRC Zen 2 is supposed to keep the same price points, but add 2 more cores to each CCX, so you'd go from a $330 8 core to a $330 12 core.
https://linustechtips.com/topic/853339-leak/#findComment-10629694
If it's true that's amazing but I just can't imagine them not trying to make extra profit from these amazing new CPUs
https://linustechtips.com/topic/853339-leak/#findComment-10629700
Who says the processes aren't going to have matured enough to where the CCX cost that little? Remember, the entire point of the CCX is that they're cheaper to produce than one 12 core die. Why do you think we have dirt cheap 8 cores right now?
https://linustechtips.com/topic/853339-leak/#findComment-10629709
