So my PC is really loud, like it's like you can hear the air flowing through it really easily - but can a bad case give bad acoustics. Like should I go for a more expensive case and that'd help the acoustics, because at the moment all I hear is the like the air flowing through the case.
https://linustechtips.com/topic/853101-case-and-acoustics/
Probably your fans and not the case so much. What kind of fans are you using and what case?
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627464
43 minutes ago, Baifish said:
Arctic F12 - 3 of these and the stock ones with the Corsair 100i v2
I am assuming they are 4-pin PWM, I don't think they come in 3-pin DC.
Have you optimized your settings between PWM and DC mode in your BIOS and set any custom fan curves?
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627875
i don't believe they're PWM because only one of my fans adjusts to my fan curve, so is it my mobo possibly?
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627883
Are they 4-pin or 3-pin fans?
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627901
Pretty sure they're 3 pin
Hmmm okay so if they are 3-pin then they are DC fans, I would first try to go into your bios and make sure all fans that are 3-pin are set to DC mode and try to config fan curves for them and get them to spin at the lowest RPM possible at lower temps of course.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627921
 Alright, i'll try that. Thanks!
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627926
Give it a go, the fans that came with your AIO should be 4-pin PWM though.
Also what case do you have?
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627944
1 minute ago, Baifish said:
An Aerocool Aero 500 (and ye my AIO ones are pwm for sure)
Hmm yeah unless you have weird vibration sounds the noise should just be from fans moving air past parts of the case, in my experience getting PWM fans that you can have spin at like 25% RPM speed at low temps is what makes the biggest difference.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627970
so really i should be looking at getting some new fans? i was thinking maybe the corsair af120 silent, and maybe the sp120 silent for my aio (idk if the stock are loud)
https://linustechtips.com/topic/853101-case-and-acoustics/#findComment-10627976
