Is it normal for temps on 3 cores to be pretty much the same at idle and the 4th core be about 7 degrees celcius hotter on an i5-2400? Im not worried cause the hotter core is at 47 ish while the other 3 around 40. Under load its about 65 Celsius while the other 3 cores fluctuate between 58 and 60. Possibly Thermal paste prob?
https://linustechtips.com/topic/852946-cpu-temps/
36 minutes ago, JPavao92 said:
speedfan has the same temps
Core Temp could be another alternative to viewing individual core temperatures. The easiest possible solution COULD be a reapplication of TIM. You're right about that. There may not have been enough paste and it didn't cover a small portion of the CPU. Or there could be a tiny pocket of air. If you're unsure, watch a youtube video that describes the Pea Method, or the cooked grain of rice method when applying TIM and give it a shot.
I'm trying to think of a way to benchmark each individual core separately to see if they all perform the same, but it's too early for my brain to function properly. Let's hope one of the cores isn't simply showing signs of failure.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/852946-cpu-temps/#findComment-10625901
I did just change the thermal paste about 2 weeks ago, the temps decreased a good chunk not that they were too bad before either but i didnt start monitoring individual core temps until after so i dont know how it was before. i havent had issues applying tim unless like you said its an air bubble ill have to order some more so i can try again. im using arctic mx-4
https://linustechtips.com/topic/852946-cpu-temps/#findComment-10625927
