Wall mount HS8
Solved by KaminKevCrew,
6 hours ago, Himommies said:I woudn't get those as those aren't padded and will cause vibrations
get this
Top kek. OP asks for wall mounts...
anyway, padding isn't a bid deal if you securely mount the speakers. Sure, they won't sound as good as possible, but it's not likely the OP will notice. Not to mention, it's really easy to add padding to just about anything with a little bit of foam.
https://www.amazon.com/Halter-Adjustable-Mounting-Surround-Rotation/dp/B01HBY4GXO
Those should work, I think. If you're worried about vibration, you could add some thin foam rubber to them.
