Sound Card and $50 Headset
Georgie
I'm looking for a $50 headset for gaming. There either needs to be a mic on it or a good mic that fits in the $50 budget. I will be using it for gaming but it doesn't have to be a "gaming" headset.
I was looking at this sound card. If you would recommend a more expensive one then please recommend a cheaper headset so that it totals around $80.
Spend 80$ on headphones/headset. I would say wait and get something like the Corsair 1400.
Quote me to get a reply!
M35's and a clip mic, screw the sound card its worse then onboard.
What about this and the sound card or a $40 sound card?
No headset, and really no soundcard.
No, sound card help higher end headphones first get good headphones and the get a Soundcard. Also try to save up for the ATH M50.
M50 is a bad value at anything over $100. M35's sound about the same with a slightly less refined detailing, for $66 they are more competitive.
Sorry I saw the M50 for about 100$ a few times.
Ok so no soundcard.
If I were to get the M35's what mic should I get? I can use a desk mic as well if that is an option.
don't be, they are a good headphone, and its easy enough to find them for $100 often enough, just that for the standard $150 there are better values.
Ok so no soundcard.
Zalman makes a cheap clip mic.
Looks about right.
Is this taking into account the cyber monday amazon sales?
Its always priced about that.
Yeah but would other deals like this be any better?
Those are better, but they have a love or hate sound signature, if you like it more its not a bad headphone though.
Those are better, but they have a lover or hate sound signature, if you like it more its not a bad headphone though.
That seems risky I think I'll just go with the first suggestion.
Go for it.
Thanks.
Any other questioned are welcomed, I or one of the other regulars here would get back to you when they could.
