14 hours ago, HeroXLazer said:
So, because I'm making a custom case, I only have enough space for 2 Flex ATX PSUs using the ADD2PSU. How would I combine the 2 AC Cords? They are 500 Watt PSUs.
I would recommend not doing that ... keep two cords...
Server 1 PC                                                   Server 2 PC                                               GEAR
CPU: Ryzen 7 1700                                                   CPU: Athlon 200GE                                               Keyboard: Logitech G Pro Keyboard
Motherboard: Aorus AX-X370-K7                            Motherboard: Gigabyte GA-A320M-S2H              Mouse: Logitech G900
CPU Cooler: Wraith Spire RGB                                CPU Cooler: Stock Cooler                                    Mousepad : Corsair MM300
Ram: Kingston 32GB 2666MHz                                Ram: Patriot Signature Line 8GB 2666MHz          Monitor: Acer XZ350CU Black 35" 21:9 144 Hz
GPU: Gigabyte G1 Gaming 980ti                              HDD: 1X WD Red 2TB                                           Headphones : Audio technica ATH-AD700X
HDD: 5X Seagate Barracuda 7.2k RPM 1TB            SSD: 1X128GB Samsung Evo                              Speakers: Logitech Z506 5.1
SSD: 2X512GB Samsung Evo                                  PSU: EVGA 100-W1-0500-KR 500 W1
PSU: HGC 850W Antec 80+ Bronze                         Case: Rosewill 2U Server Chassis
Case: Rosewill 4U Server Chassis
https://linustechtips.com/topic/852040-power-cords-combiner/#findComment-10618982
On 10/28/2017 at 8:48 PM, HeroXLazer said:
Okay, can I plug both of them into the same surge protector, or should I use two wall plugs?
I would recommend you to plug them into surge... if possible grab a cheap UPS... some of them cost bellow 100$ and it can save the day during power outtage !
https://linustechtips.com/topic/852040-power-cords-combiner/#findComment-10635281
