Alright, probably my last-ish computer build for my first computer. I am an iMac person, so most of this stuff is new to me, I just want some feedback. I’m going for a white and aluminum theme for my whole desk, and I want to keep the price around $1000-$1500, but the cheaper the better. Also any suggestions for case lights, or desk lights that are RGB or Blue are greatly appreciated. Also any cheap white and black gaming chair links would be nice.
 Thx in advance~!
Computer Configuration:
Graphics Card
https://www.amazon.com/gp/aw/d/B01JHQSZ40/ref=mp_s_a_1_4?ie=UTF8&qid=1509140176&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=gtx+1070&dpPl=1&dpID=51xWIIzYafL&ref=plSrch
Motherboard
https://www.amazon.com/ASRock-AB350-PRO4-ATX-Motherboard/dp/B06WWF165R
Storage/Hard Drive
HHD
https://www.amazon.com/Seagate-BarraCuda-3-5-Inch-Internal-ST4000DM005/dp/B01LNJBA50/ref=sr_1_3?s=electronics&ie=UTF8&qid=1509140746&sr=1-3&keywords=4tb hard drive&tag=linus21-20
SSD
https://www.amazon.com/gp/aw/d/B00LMXBOP4/ref=mp_s_a_1_1?ie=UTF8&qid=1509140459&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=samsung%2Bssd%2B256gb&dpPl=1&dpID=412M8LGGfrL&ref=plSrch&th=1&psc=1
Power Supply
https://www.amazon.com/dp/B073GY89G5/?tag=pcpapi-20
Fans
https://www.amazon.com/gp/aw/d/B00KB8CB9O?psc=1&th=1
Memory/Ram
https://www.amazon.com/gp/aw/d/B01HKF4ZUI/ref=mp_s_a_1_4?ie=UTF8&qid=1509072372&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=gaming%2Bddr4%2Bram&dpPl=1&dpID=4180NUuOuXL&ref=plSrch&th=1&psc=1
Case
https://www.amazon.com/dp/B01HDUVMBU/?tag=pcpapi-20
Processor/CPU
https://www.amazon.com/dp/B06XKWT8J4/?tag=pcpapi-20
Peripherals
Headphones
https://www.amazon.com/gp/aw/d/B015WKYI50/ref=psdcmw_3015405011_t1_B01MUI0TN6
(2) Monitor
https://www.amazon.com/FreeSync-1920x1080-Samsung-Professional-Monitor/dp/B072K3Z5NC/ref=as_li_ss_tl?ie=UTF8&qid=1500993415&sr=8-1&keywords=pixio+px245c&linkCode=sl1&linkId=a84b9c9014cccccf3f7e55c410213958&tag=linus21-20&th=1&psc=1
Edited by XxAssassin207xx
https://linustechtips.com/topic/851909-need-feedback-entry-level-build/
 Thx in advance~!
Graphics Card
https://www.amazon.com/dp/B071L1VGQW/?tag=pcpapi-20
Motherboard
Storage/Hard Drive
HHD
https://www.amazon.com/dp/B013HNYV42/?tag=pcpapi-20&th=1&psc=1
SSD
https://www.amazon.com/dp/B01M9B2VB7/?tag=pcpapi-20
Power Supply
Fans
Memory/Ram
Case
Processor/CPU
Peripherals
Keyboard/Mouse
https://www.amazon.com/gp/aw/d/B00W3E6YV0/ref=mp_s_a_1_4?ie=UTF8&qid=1508881265&sr=8-4&pi=AC_SX236_SY340_QL65&keywords=white+gaming+pc&dpPl=1&dpID=41G0EfMN4iL&ref=plSrch
Second Mouse (for my Mac)
https://www.amazon.com/gp/aw/d/B00WEVLGEW/ref=pd_aw_fbt_147_2?ie=UTF8&psc=1&refRID=M9PPQ1FVCSF0MWCZ1BHF
Mousepad
https://www.amazon.com/gp/aw/d/B014W3FMP8/ref=dp_ob_neva_mobile?th=1&psc=1
Headphones
Headphone Stand
https://www.amazon.com/gp/aw/d/B01GJQ7NAS/ref=pd_aw_lpo_201_bs_img_1?ie=UTF8&psc=1&refRID=WYK9AREBPAX2XM7EXPNF&th=1
Phone Stand
https://www.amazon.com/gp/aw/d/B014INJCT4/ref=pd_aw_fbt_147_2?ie=UTF8&psc=1&refRID=A08RXKH159CN30BSEV7T
(2) Monitor
I would get used GTX 1070 instead. Everything else looks good.
I don't question the storage, you must have your reasons.
M.2 is good and fast. Samsung or WD either one should be fine.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
Just now, goatfeed123 said:
Get the 1500x, change the WD Green m.2 ssd for a different one, would recommend Samsung ssd, and do you really need a 3tb hdd?
and the 1600 is only a tad bit more than the 1500x
i whould say get that to make your pc last longer
I'd get 1400 or 1600 at best, OC it to 1500X speeds and wait for Zen 2. Motherboard replacement will not be necessary.
Main PC:
Case: TT P3
HTPC:
Just now, Ethocreeper said:
you mean the 1200?
Nah, 1400. 4 cores 8 threads is enough for now, and the CPU is cheap. Upgrading later will be easy.
Main PC:
Case: TT P3
HTPC:
Yeah, in fact I do, I might even need to get an external 4TB Hard-Drive, I do a lot of filing and editing for videos. How’s this for a SSD? https://www.amazon.com/gp/aw/d/B00LMXBOP4/ref=mp_s_a_1_1?ie=UTF8&qid=1509140459&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=samsung%2Bssd%2B256gb&dpPl=1&dpID=412M8LGGfrL&ref=plSrch&th=1&psc=1
swap for this ssd for the same price slightly better specs and honestly just better reputation.
https://www.amazon.com/Blue-NAND-250GB-SSD-WDS250G2B0A/dp/B01LY154MY/ref=sr_1_1_sspa?s=electronics&ie=UTF8&qid=1509140208&sr=1-1-spons&keywords=m.2%2B240gb%2Bssd&th=1
That poor 580. Ultrawide 1080 with 144hz, too bad Vega 56's arent easily available for 399.   You could easily justify that 100 bucks.
I don't even know why I'm an ASUS fanboy...but I am.
1 minute ago, RandomGuy13 said:
Here is a tip, You can use this website to make your PC parts list, It makes it easier to make and share. I have gone ahead and compiled you a list based on the parts you have listed.
https://pcpartpicker.com/list/YTmb7h
Hope this helps.
I wouldn't necessarily used it to find the cheapest seller, But its nice to make your  pc lists in this website, makes it easy to share and for people to view.
Okay, Cool. Thanks a lot!
 Thx in advance~!
Graphics Card
Motherboard
Storage/Hard Drive
HHD
SSD
Power Supply
Fans
Memory/Ram
Case
Processor/CPU
Peripherals
Keyboard/Mouse
Mousepad
Headphones
Headphone Stand
Phone Stand
(2) Monitor
NEVER NEVER NEVER NEVER BUY A 5400 RPM HDD
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
Is this SSD alright? https://www.amazon.com/gp/aw/d/B00LMXBOP4/ref=mp_s_a_1_1?ie=UTF8&qid=1509140459&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=samsung%2Bssd%2B256gb&dpPl=1&dpID=412M8LGGfrL&ref=plSrch&th=1&psc=1
I must've missed it. I agree, that thing is as slow as molasses.
Main PC:
Case: TT P3
HTPC:
Just now, XxAssassin207xx said:
More than alright! I was just trying to shave the $$ By all means get that one
I have it and it's good. I have the 500GB Version. Been using it for 2 years, still at 100% health.
Main PC:
Case: TT P3
HTPC:
Main PC:
Case: TT P3
HTPC:
Just now, RandomGuy13 said:
No? I assume you mean as a PC drive. There are applications for 5400 RPM drives.
What would you suggest? Lol
They are very slow. Get a 7200rpm hdd
3 minutes ago, Paunae said:
Side note.... WTF is this....can any one agree?  If it looks too good to be true it probably IS too good to be true?
https://www.amazon.com/7200RPM-Internal-Enterprise-Desktop-Warranty/dp/B00X38UO70/ref=sr_1_18?ie=UTF8&qid=1509141018&sr=8-18&keywords=3Tb
also, please use pcpartpicker, it makes life easier for everybody
ORDERED!!  That will be a good addition to my Drobo!!!
