That`s cool.
Do you have the model of MB. You can look in the Billing it should say.
Or If he does not know, just restart and go to Bios ( delete ) . You should be able to see the MB number. Then exit without saving any change, just in case.
Then go to Asus............
https://linustechtips.com/topic/851897-help/#findComment-10615666
43 minutes ago, andy_gatts_510 said:
I was asking for my friend who has a prebult by asus
I could find it
Quote people please
Also if you could find it why didn't you send it..?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/851897-help/#findComment-10615818
