Im having a weird issue i was playing divinity 2 original sin when my cpu just cut off and said there was a power surge and the computer cut off to protect itself and upon reloading it takes me into the bios ...and now every time i load D2OS my computer crashes and says power surge its happened 3 times now before i stopped so i dont break anything i have no clue what caused it the 1st time or why it keeps happening please help me figure out how to fix it .. do i just need a new power supply  the computer is maybe 1 year old.
I7 5820K
AX860 power supply
x99 deluxe (i know weird departure from rest of build long story)
980ti 6gb
Windows 10
16 gb corsair vengance
https://linustechtips.com/topic/851256-power-supply-fail/
It's just ASUS anti-surge being annoying... I recommend you simply turn it off.
Don't worry about the PSU, since it's a very good unit.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/851256-power-supply-fail/#findComment-10608924
I can't seem to bog the system down to the point of the issue you're having I loaded up as many CPU benchmarks as I could. have you ran any other game? or benchmarks to see if it just that game? I have called Asus for help with my X99-M WS for q code I was getting and they are really fast and helpful you can call them and they might be able to help you
https://linustechtips.com/topic/851256-power-supply-fail/#findComment-10608982
ya if the game was cheaper I would buy it and see if that happens to me. I know I have never gotten my system to draw more than 600 watts form the wall and that was with me running my CPU at the same speed as yours and with 4 stress tests running on 4 screens
https://linustechtips.com/topic/851256-power-supply-fail/#findComment-10609010
