You can find usb Bluetooth adapters super cheap on Amazon, cheaper than a pi for sure. $5 or so.
Then in audacity or whatever you're using, select it as the input
Fanboys are the worst thing to happen to the tech community World. Chief among them are Apple fanboys.
I'm not sure what you mean by an audio receiver for your computer, do you mean you want to take your phones audio and send it to your computer as if it was a mic.
If you want to just send sound from your phone to speakers, you could something like this, https://www.ebay.com/itm/USB-BLUETOOTH-WIRELESS-3-5MM-STEREO-AUDIO-MUSIC-RECEIVER-ADAPTER-DONGLE-AUX-A2DP/131579597994?epid=2175444083&hash=item1ea2c154aa:g:OXMAAOSw~gRVzuEl
It just takes a USB for power and then has an audio jack which you could plug speakers into.
