so i wanna get into litecoin mining i have a problem though i can only have one gpu since its a mini itx mobo
other specs are:
i3 3240
8gb ram
500w psu
p8h77-i
i know the ram and cpu are overkill but it was my old lan rig that i dont have need for anymore so i want to turn it into a mining machine
So on to my question what is the best gpu for under $180 for mining
i've seen 7850's for as low as $95 on ebay is that viable for the price and will i see a return using it
any help is appreciated thanks
also what would be a good os as i am about to run out on the trail version of win 8.1
its GE (pause) TechNicks
my rig plus everything i have bought for it http://pcpartpicker.com/p/30sNV
https://linustechtips.com/topic/84998-litecoin-rig-help/
