system build System Build Help
Solved by TheRandomness,
A few things:
1) Please press the 'BB' button and then copy that box over to here to have it format properly.
2) You cannot overclock that CPU, you have to have a 'k' series CPU to overclock it. If you don't want to overclock, downgrade to a B250 motherboard and get a cheaper cooler.
3) 8GB is still a fine amount for RAM if you're just a gamer.
4) You should have some form of long term storage, such as a 1TB HDD just in case.
5) If you choose to do the thing I said in the latter part of step 2, then you could try get a 1070 instead.
6) You could easily save money on the PSU and get something cheaper, use the PSU tier list linked in my signature to find a good model for as cheap as possible.
