Late 2017 Build
Go to solution Solved by Aidanlockett1,
1060 and r3, the 1300x and 1400 are both quad cores, just overclock the r3
Im confused with what CPU to pair with the GTX 1060, is it the Ryzen 3 1300X or the Ryzen 5 1400.. I might go for the 1400 but it would mean picking up a 1050Ti, budget reasons *ptff*
Specs 1
R3 1300X
B350 Mobo
GTX 1060
8GB RAM
1TB HDD
550W PSU
Specs 2
R5 1400
A320 Mobo
GTX 1050Ti
1TB HDD
8GB RAM
550W PSU
https://linustechtips.com/topic/849526-late-2017-build/
Are you ordering from US and shipping to Philippines?
Some prices may be different if you're buying locally.
PCPartPicker part list: https://pcpartpicker.com/list/ktY2XH
Price breakdown by merchant: https://pcpartpicker.com/list/ktY2XH/by_merchant/
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor  ($154.88 @ OutletPC)
Motherboard: ASRock - AB350M Micro ATX AM4 Motherboard  ($40.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($77.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($40.99 @ Best Buy)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB GAMING Video Card  ($199.99 @ B&H)
Case: Rosewill - SRM-01 MicroATX Mini Tower Case  ($19.99 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $561.81
https://linustechtips.com/topic/849526-late-2017-build/#findComment-10590018
Total: $561.81
dont cheap on psu go with base r3, and overclock with a 1060 and an ssd
https://linustechtips.com/topic/849526-late-2017-build/#findComment-10590025
That's not cheaping on the power supply lol, a CXm is perfectly fine for this build, it's priced cheap cause its on offer.
https://linustechtips.com/topic/849526-late-2017-build/#findComment-10590027
