Hello, I am new to cooling using AIO's and was wondering if I can get some advice.
As of now, I am using a  I5 4690K @4.2 Ghz but will be upgrading to a 7700k later this year. I have been looking at several brands and have come to the conclusion that corsair seem to be the best.
I have a few questions however;
  1. what is the difference between the H115I and H110I?
  2. If the AIO was to leak and damage components, would Corsair replace said parts?
  3. If the pump was to die, potentially causing my CPU to die due to heat, would that be covered?
My last question is why EKWB have stopped making the AIO's they used to sell. Thank you for reading and hope you can help :D
EDIT: I forgot to ask what you would recommend to get.  It will probably be put into a corsair air 540
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/849350-looking-for-a-cpu-cooler/
1. One is made by CoolIT and the other is made by Asetek. They're more or less the same TBH.
2. IIRC, if Corsair deems it to be their fault then they should cover the parts... but the chances of the AIO leaking is very low in the first place.
3. The CPU would thermal throttle. It has protections to ensure that it doesn't fry itself.
4. EKWB is introducing their EK-MLC AIOs "soon".
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
Thanks, what AIO would you recommend? The H115I, H110I Or H100IV2?
Doesn't exactly matter. There's no real appreciable difference between them. Just get the cheapest one.
Ok, thanks for your replies :)
A) they have cheap full loop options instead
B) they are making a new gen of clcs.
Want to custom loop?  Ask me more if you are curious
Ah ok, I wouldn't trust myself to do a full loop. Only thought about them because Jayztwocents did a video on it
I recomended the fractal celcius s24/s36 or the evga CLC 280, they outperform the competition handily.
If you have space for it the Arctic freezer 240 is insane value, push pull and super thick radiator.
