Hello,
I bought myself a Gtx 1060 2 Months ago and Upgraded my AMD HD 7950, I got it to run on my Tv with a HDMI Cable until i Updated the Drivers 3 Weeks ago.
After i Updated them the TV told me "Invalid Format",wich i went to the Living Room TV and i got it to Work there. I let my PC run over Night, after i Rebooted my PC it worked again. After that i didnt turn it off until Today.
So i put in my AMD GPU and Uninstalled the Driver's. I tried to re-install the GPU Drivers but Geforce says: "The Graphics Driver couldn't find a compatible Graphics Card"
Specs:
I7-3770
GTX 1060 / AMD HD 7950
Pre-Build Motherboard
Prebuild Powersupply 600W
16GB DDR3
SSD 128GB Sandisk
WD BLue 1TB
https://linustechtips.com/topic/848577-graphics-card-wont-post/
7 minutes ago, Klouuse said:
Use DDU to uninstall the drivers
https://www.wagnardsoft.com/
https://linustechtips.com/topic/848577-graphics-card-wont-post/#findComment-10579470
Just now, Klouuse said:
It did work, but when I installed thethe driver it gor back to ,,invalid format,,
Probably try hooking it up to a monitor, the TV just might not respond to the resolution the GPU is throwing it.
https://linustechtips.com/topic/848577-graphics-card-wont-post/#findComment-10579612
Problem is, I sadly don't own a monitor.
You could either lug it to a repair shop and ask nicely to borrow a monitor.
Or find a cheap something with DVI on craigslist/let go/close 5
Not sure what else it would be that prevents you from using the TV as a monitor assuming the GPUs are working fine.
https://linustechtips.com/topic/848577-graphics-card-wont-post/#findComment-10579641
Hey wait, does your motherboard have HDMI out? Try that first with no GPU.
https://linustechtips.com/topic/848577-graphics-card-wont-post/#findComment-10579671
