i5 8600k air cooler?
skeeler88
I plan to buy the i5 8600k and pair it with an H212 Evo or a Cryrig H7 Quad lumi. Will either cooler be able to handle the temps of the processor? Any info or recommendations would be appreciated.
Don't get 212 EVO, very mediocre (Cryorig M9i is slightly better and has a lower price)
Cryorig H7 is a nice choice but may not handle heavy OC well
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
What are your goals ? major  over clocking, minor, or just stock?
main system build --> i7-7700K (at 5.0 ghz), MSI Z270 SLI Motherboard, corsair vengeance lpx 8gb ddr4 2666mhz,  costume liquid cooling loop with 360 mm radiator on CPU, GTX 1080 gigabyte windforce OC, 1TB WD drive, 128 gb samsung nvme m.2, EVGA 850 watt semi modular power supply, CM storm stryker case (ya not ideal for costume loop), VIOTEK GN34C 34 inch curved monitor <----
We are told to remember the idea, not the man, because a man can fail. He can be caught, he can be killed and forgotten, but 400 years later, an idea can still change the world."
Umm since this is my first PC itll most likely stay stock or minor overclock at most.
Then the H7 will serve you well
Desktop specs:
The H7 quad lumi looks cool and im doing a moderate rgb build so it goes well with my parts
yes the H7 will do good, or if you have the space Noctua does an amazing job at keeping these cpus cool.
What about the Deepcool GAMMAXX GT?
what about the Deepcool GAMMAXX GT?
You mean GammaXX 400 right? It's on par with 212 EVO, again the Cryorig M9i and H7 is a better buy
Desktop specs:
ya no they preform about the same. if i where to chose a cpu cooler i would go noctua nh-d15 or cryorig R1 ultimate. the amazing performance of these will avoid all heat issues that this cpu will throw at it. cpu coolers like the ones above work but just barely. and minor overclock's will give them a run for there money. if ur going to drop so much money into a cpu why not take good care of it. alot of reviews are saying that thermal performance is really bad and these chips heat like crazy. i would go with a strong air cooler.
