1600x Cooling Solution
Go to solution Solved by Ryzen-9,
Just now, Mister_Shots said:
As for the cooler you sent me at first I am reading I can order a free mounting bracket from the manufacturer with proof of purchase.
Ok well I found another one that is actually meant for that socket that I think would be better then a Hyper 212.
https://pcpartpicker.com/product/TsL7YJ/thermalright-cpu-cooler-machodirect
I got the 1600x brand new for 50$ less than the non x variant. Saved 50$ on the cpu now I can spend it on the cooler. Am looking for a front to back mounted air cooler. (since this is my first build I don't want to jump into water just yet. Plus I hear Ryzen does great on air cooling because of the metal between the die and heatspreadder.) The reason I am on here instead of Newegg, is because I was reading review after review with no performance results. Rather 90% of the reviews just being people reviewing how easy/hard it was mounting it. If you have a suggestion don't hesitate lol. Sorry if I sound a little annoyed haha.
https://linustechtips.com/topic/848003-1600x-cooling-solution/
6 minutes ago, №☢ said:
Looks very promising for the price. It says it's compatible up to AM3+ how hard is it to find a mounting bracket?
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573301
cooler master hyper 212 evo
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573304
Just now, №☢ said:
I didn't look at the socket compatibility sorry. I can find a different one though.
any one can go into pc part picker and find a cooler how about giving a reliable answer
Peripherals
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573311
1 minute ago, №☢ said:
NO! THE HYPER 212 ISN'T THE SOLUTION TO EVERYTHING COOLING. It is very good for its price but it can't cool everything.
its better then the stock 1600 cooler and the stock cooler is already good enough for a 1600 @ 3.8 so i think the hyper 212 will do just fine
Peripherals
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573318
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573320
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573325
Get the hyper 212 Plus
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573337
This one will do perfectly! :D The noctua is great but a little out of budget but thank all of you anyways!
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573347
5 minutes ago, №☢ said:
He got a 1600x and the hyper 212 is not enough, it just isn't big enough.
it will do just fine
Peripherals
https://linustechtips.com/topic/848003-1600x-cooling-solution/#findComment-10573351
