Zip Tied CPU Cooler
Go to solution Solved by LHJKO,
9 minutes ago, Fearless247 said:
Great, I read about someone doing about the same thing I am, but everyone said It would not be good for the long term, so would you say this could be a permanent solution?
now that i think about it the zip ties are plastic and the heat will affect them dont do it for long
Hello, I have a Optiplex 390 with a I5 2400 on the LGA 1155 Socket, So it's the small form factor with the weird dell stock cooler. What I want to do is put the 390 motherboard and CPU into a mid tower case, I have a intel stock cooler I want to mount, but the holes do not line up, so my question is can I mount it with zip ties permanently? I have industrial strength zip ties that are very strong.main-qimg-9914b28e6107a7c857caa99736912b8d-c.jpg.12e65c100cf91438921e83a66ce6a6b2.jpg The One I Want To Mount
https://linustechtips.com/topic/847994-zip-tied-cpu-cooler/
as long as its being held down and its actually making good contact to the cpu it should be fine
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/847994-zip-tied-cpu-cooler/#findComment-10573116
Peripherals
https://linustechtips.com/topic/847994-zip-tied-cpu-cooler/#findComment-10573138
