I am not new to tech. This is a computer that I use daily. It has a biostar t5xe cfx sli motherboard with a core i7 870, 14 gb of ram, an EVGA 1060 ftw+, an asus 750 ti oc, 1tb hard drive, and a 750 gb.
I have been working on this all day. I am not just asking to get told to get a new computer, I know the age but I dont care. if you tell me to get something new, I will ignore you. I just have the strangest happening with my computer.
I can't get the usb to be found by the bios. I have found that the usb controllers are only found in windows. I have the latest bios version for this mother board, 2.66.
This was all started because I wanted to reinstall windows. When I set it up with an 80 gb sata hard drive I had lying around, it installed windows 10 to my 1tb, it also saved an essential boot file to the 80 gb. After a certain amount of time, windows 10 got an update and I stopped having the ability to boot my computer.
Now comes to the present. Could someone please help me out with my struggles? Thanks.
https://linustechtips.com/topic/847571-i-need-some-help-with-some-tech-stuff/
Did you disable USB controller in the bios. Maybe your control died. Maybe a windows reinstall could fix this as a bad install is likely as Nehlam is not officially supported by win10.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
 dont belive that to be the issue, as when Im in windows, I have no problems with any of my usb devices. In fact, if the usb controller died, I wouldn't have been able to use my usb keyboard to move about the bios. That and if it did die, I highly doubt all my usb devices would continue working on this computer. I appologise for being to hasty.
From what I remember (as my memory is crap - this might not be the case), around when that was produced, not all motherboards could boot from a USB device, so that may be the problem you are having. If it is, you might just need to burn the latest win 10 to a dvd and boot from that to either do a windows repair (if that will work with your predicament) or full reinstall.
