So I'm getting a bit mental about the cooling on my PC. When summer hit I noticed a huge spike in temps and I fiddled with the fan placement to try and get some lower numbers. I may have found a sweet spot but I wanted your opinions on if its doing more detriment or if its ok how i have it.
I have a full EKWB kit with a top mounted 360 rad. Three Corsair SP120 fans on the radiator in pull (into the case), one SP120 for an exhaust on the rear, and the two fron Corsair 140mm as exhaust on the front of the case. Its a Phanteks Evolv ATX case so its already limited in airflow. I took out the front dust filter and did a custom mod on the top to allow more air into the case.
If its working then run with it? Or should I fix something for better results?
My idle temps are around 30C and my load temps playing games is at 55C
Intel i7 6700k|Asus Maximus VIII Hero|Asus Strix 1080|Gskill DDR4 3200|950 Pro M.2|Corsair RM750|Corsair OBSIDIAN 500D|Corsair K65\G65|SteelSeries Arctis 5|Asus PB277Q|PG279Q
https://linustechtips.com/topic/847556-proper-fan-placement/
Intake on front, exhaust on back and top is generally what's recommended
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568081
Just now, emosun said:
is 55c supposed to be hot or.......?
I would guess not, I'm pretty sure that's normal for what he's doing
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568089
Yeah I've been building for many years but this case is terrible for airflow. The front is extremely restrictive and I also cant put the radiator on the front of the case. I'm trying to get past the problems of this Phanteks case.
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568094
It’s not high but if your paranoid, put your fans not on the radiator as intake and the rad fans as exhaust, but remember to get fan filters for the intake
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568096
Additionally, having your radiator pulling in has effects on the rest of your build's temps.
Basically, if your radiator pulls in, your CPU will be cool but the warm air coming from the radiator will increase temperatures in GPU, other components etc. Pulling out, and your CPU will be slightly warmer but the rest of the build will be cooler. You could also have the rad and another fan at the back pulling out, and pull in from the front.
BTW, 55 degrees is really good, I have no idea why that could be an issue.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568100
Because I'm crazy. Thats not at full CPU load though, which seems to be my worst. I hit 70C at 100% CPU.
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568112
2 minutes ago, emosun said:
pc fans aren't really capable nor is his case sealed enough to create any sort of pressure
exactly.
if you have 3 out and 1 in, then more air will be sucked out than in, which means that the air will have to equalize through the very not-airtight case. many people have dust filters on all their intakes, so if you have positive pressure -- no dust. if you have negative pressure then your filters are useless
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568121
that's not bad at all.
85+ is where you should start to worry.
Laptop:
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568126
and if you have a can of air you blow the dust out in 15 seconds every couple months bfd
yeah basically. except for that it takes 5 minutes and it's every 2 weeks.
Laptop:
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568132
Even 70 isn't terrible. 80+ is when there are issues. Still, I get that some people want to squeeze as much out of their expensive cooling rigs as possible ;)
My PC:
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568138
11 minutes ago, Snipergod87 said:
In general yes however that would net is negative pressure inside the case which is not recommended.
no you're not accounting for the restriction the radiator brings. it is 3x120mm but they don't move as much air as they would without the rad vs 2x140mm completely free of obstructions
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568140
Thats what I mean. I just want optimal placement and best temps with my setup. I'm not actively working to get everything down to 30C on load or anything.
https://linustechtips.com/topic/847556-proper-fan-placement/#findComment-10568148
