https://linustechtips.com/topic/847527-first-pc-build/
Wouldnt waste the money on a 950, also: SSD
https://linustechtips.com/topic/847527-first-pc-build/#findComment-10567713
That build looks pretty decent for a beginner but I would recommend a better gpu. The 950 will struggle if you  are trying to play any newer more graphically demanding games and won't even get great frames in older less demanding ones. I would really recommend getting a 1050ti or better as in my mind that is kind of the minimum for getting enjoyable frames at 1080p. Even if you can't afford the 1050ti a 1050 would be better than the 950. In my opinion the 950 would be a waste of money for this build as there are others in that price range that perform miles better.,
https://linustechtips.com/topic/847527-first-pc-build/#findComment-10567735
Thanks :D
https://linustechtips.com/topic/847527-first-pc-build/#findComment-10567744
3 minutes ago, RRichards said:
Oh didn't see the 950 for free nvm
Thanks :D
https://linustechtips.com/topic/847527-first-pc-build/#findComment-10567749
