i have a fx-6300 i only have a air cooler on it sits around 50 degrees under load.
should i get a aio and overclock it or should i just upgrade to a new cpu and if i do are there any suggestions of what to get?
i mainly use it for gaming i am looking at upgrading my gpu to a gtx 1060 i don't have much money to spend either.
After looking in my bios there are some overclock's that are already set that i can choose i just don't know if they are good or not.
System
amd fx-6300
gtx 660
16g of ddr3
asrock 980de3/u3s3
600w powersupply
https://linustechtips.com/topic/847149-help-overclocking-fx-6300/
How much money do you have to spend on a new system? Yours is pretty dated and a new system could help.
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
I had my 6350  OC pretty good on air. I did upgrade from a Hyper D92 to H100i v2 because I was going to upgrade to Zen. I got it early because I could and it helped to cushion the cost of my R7 upgrade. Felt like it was $100 bucks cheaper.
But no, I didn't really need it. I was able to get to 4.4 on my 92mm cooler, and up to 4.7 on water. I couldn't get higher because the chip didn't let me. But the water wasn't necessary, because not much difference between 4.4 and 4.7.
