Hi,
My family and I are looking for a NAS to buy,
-We have 3 people
-Need to backup 3 computers totaling 2.5TB of data
-Need an easy way to store and access family pictures and videos
-Need a stable way to back up the family pictures as we don't want to lose them
-Need a NAS which is fast and can runs apps like PLEX
Hello, I like computers
https://linustechtips.com/topic/846757-help-me-pick-a-nas/
Budget?
Magical Pineapples
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559332
get an old core 2 quad or core i3/i5 add 4-8gb of ram and get 4 3tb hdd run in raid 5.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559338
PS: Don't forget to use google photos on the simple quality. Gives unlimited storage space that way.
CPU R7 3800X    Motherboard Asus Prime X370 Pro  RAM  24GB Corsair LPX 3000 (at 2933Mhz)    GPU EVGA GeForce RTX 3070 XC3 SC  Case Phanteks Enthoo Pro M
Storage 1 x 1TB m.2 (Windows), 1x 500GB SSD (Linux Mint), 1x 4TB SSD (for data Samsung 870) PSU Corsair RM1000  Cooling deepcool ak620(? probably)
Synology NAS 2 x 8TB
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559341
When the product is free and unlimited you're the product.
Magical Pineapples
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559345
Does it really matter?
If your NAS fails catastrophically even that RAID setup wont help.
So an additional backup simply won't hurt. A backup is a backup.
You're probably not a professional photographer/videographer - so not like copyright is an issue. Practicality for an average person is a good thing to strive for. IMO
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559348
Well i never said you shouldn't have backup?
RAID/ZFS would help and the chances of 2 or more drives dying is very unlikely if you buy your hard drive from different batches. You're data isn't save with google as well, recently there were know to delete backups when device has been inactive over a month period.
My NAS has been acting as my family "google photo" (Plex Mobile Upload), "Netflix" (Plex and Sonarr) for over 2 and half years now. I mean the initial investment was high but the end result is, i don't have relay on services who has control over my data. I have multiple different backup location which in event i failure at my main server i still can get majority of my data back.
Magical Pineapples
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559358
I raid would help and the chances of 2 or more drives dying is very unlikely if you buy your hard drive from different batches. You're data isn't save with google as well, recently there were know to delete backups when device has been inactive over a month period.
But OP didn't strike me as that determined for invest a lot - but did mention backing up twice and easy access to family video and photo. *shrug*. And I just mentioned google photos as a very easy but working solution.
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559380
Plex app supports pretty much all platforms and have remote access. It has mobile upload and than you could create scripts to backup that folder diectory and create a library for each users.
If you won't pay plex pass, there is other options such as NextCloud/Emby which has similar options which has more control/customization.
Just now, SurajBlue said:
Well... Max $400-500
For new parts = No
Drives alone will cost around 300 dollars by itself.
Second server = Sure
1 minute ago, SurajBlue said:
If I wanted to build a NAS what components should I use, what OS should I use and what would the total be
FreeNAS = It free and it has ZFS but that could mean you have aim for at least 8GB of ram which your budget won't able to fit.
Magical Pineapples
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10559402
Get a low end APU/CPU, like some 25W TDP AM1 platform thing. Stick 4GB of ram in it, a small boot drive, and stick it all in a mATA or ITX case.  This can be done for under $200.
Then just populate it with drives and install Ubuntu server on it.
If this will server as a primary storage, don't do RAID in it, make it back up one drive to the another. If you already have back ups elsewhere or are using it as a back up RAID is fine.
https://linustechtips.com/topic/846757-help-me-pick-a-nas/#findComment-10566719
