Hey guys, recently I started building my computer. So I put everything together, and it didn't turn on. So I was looking making sure everything was put in to correctly, when I noticed my CPU socket pins were bent. The CPU was already put in while it was bent, so I am hoping that my CPU is not broken and that I can just get a new one. Anyone know if my CPU could have been fried or broken? Thank you!
https://linustechtips.com/topic/846660-bent-cpu-socket-pin-symptoms/
CPU should be fine. Depending on how bad the damage is you can usually fix the bent pins. (Post pics?)
Ok thank you. By the way, I actually did try to fix the pins and but it back in and it still did not bend. A friend who is very good with computers looked at the MB with me and he said one of the pins were very loose, so he concluded most likely that when I put the CPU in the socket it gets bent back and that the best option would probably be to just replace it. It is most likely what I will do.
