750Ti - one 4K screen + 2 1080p screens. Will it work?
Solved by James09,
Have a look at the manufacturer's website of the specific card you want to purchase. They will usually include a Maximum Number of Displays listed. As long as its 3, it won't matter which 3 of the ports are populated. If you just need something with ports you might consider something in a similar price range as the 750ti but current gen, such as 1030 / 1050 or something from the red team. Most of those don't even need a power input, which I'm guessing is one of your requirements. Getting something current gen will usually result in more updated connectivity options. "Usually"
Just my 2c
