I got my new (err, i mean 2 generations old) 6600k about a half year ago and in that time i've accumulated some pretty good hardware to go with it. I droped some cash on a H100i and some exhaust fans and woah. Imm running 4.7 ghz with a steady <30 C idle temp and a ultra quiet fan curve having them set at 500 rpm at 20 C and increasing 100 rpm every 10 C. In gaming it never reaches 70 C and I have experienced no instabilities at 4.7.
The question is, how do I stack up. Idd like to hear from others what their experiences are with a 6600k and should I push it further? Imm not looking to fry the chip but I am not planning on using this one for more than a few years. With my current OC I have not messed with the voltage at all but I have the base clock at 105mhz (I was scared to push the main clock any further). My ambient temp is a cool 20 C and I have a lot of headroom for cooling.
The rest of my hardware is as follows:
GPU: Strix 1070
Mobo: ASUS Z170-a
Ram: 2x4 2133 G.skill
Storage: 120gb boot ssd, 1tb WD main storage +, 1tb salvaged seagate hdd from a laptop.
Capture.PNG.e8a692bd2c2e0b017d7955516a56d147.PNGCapture2.PNG.5dce794dab998aeebf77d55e8f40f0ee.PNG
https://linustechtips.com/topic/845972-how-are-my-temps/
You can go further. 1.4v should be your max since you plan on using this CPU for quite a while. Hoever, if you feel adventurous (like me, I have a 6700k) you can go to 1.45v, though you might need a delid to keep temps down.
EDIT: Wait, you aren't messing with voltage at all? How is that possible? If you mean to say that you are just allowing the BIOS to do whatever the heck it wants to do in regards to voltage, don't do that. Use adaptive or some other mode that gives you control over the voltage, otherwise you could have voltage spikes and / or instability.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/845972-how-are-my-temps/#findComment-10551847
You get a better overclock by raising the voltage, but if you implement too much voltage, it will be unstable. Your temps look good from a temperature perspective and I think you could raise the clockspeed, 80C is the sweet spot for temps and 90C is pushing the limits and anything exceeding 90C, isnt advised and your CPU will probably start to thermal throttle. A normal ambient temperature of 20C is good, and assuming you have an adequate cooling solution (AIO or air cooled), temps souldnt be a problem. There is definitely some more overclocking potential for this CPU xD
https://linustechtips.com/topic/845972-how-are-my-temps/#findComment-10551891
