Hi guys, I'm planning to build a Animation / 3D Modeling/Rendering Workstation and a bit of gaming .What CPU, Motherboard and GPU should I go with?
Mostly my work focuses on Apps like Toonboom, Paint Tool SAI, 3DS Max, Autodesk Maya, Adobe Photoshop and Illustrator. If you guys can help me out, I'd appreciate it.
https://linustechtips.com/topic/845885-animation-3d-workstation-pc-build/
8 minutes ago, sjr said:
So from personal experience with Maya you'll want at least 64GB DDR4 and an SSD.
Some of the features in those programs don't utilise the GPU so instead of just focussing the money solely on GPU balance the spend on CPU and GPU.
I already have an SSD. I'll fit 64gb DDR4 RAM into my budget. tnx.
Edited by johnstorm17
added gb in 64
