Hey I'm back here again.
After updating my Bios to 902 ( most recent as of writing) my ram speeds are still lower then the box advertising. 2666.
Manually changing the speeds in bios causes the PC to not Post. It attempted 3 times and then booted to safe mode and asked to run a set up.
( I can't find helpful information because I'm not looking hard enough)
I payed a little extra money for the 2666mhz ram, I want to use that extra speed however minut it may be.
AM4 1800x
Asus prime x370 pro
X4 4gb Corsair LPX 2666mhz
GTX 1080
No cpu over clocking has been done .
Picture is to show that bios is 902 updated
https://linustechtips.com/topic/845185-am4-ram-speed-issues/
1 minute ago, TheRandomness said:
Did the previous BIOS allow for those speeds?
i can assume So, as i was Running 511 but i gave up trying to Force it to Run at its Rated Speed. the MSI board that Killed itself and the Ram wouldent Run at 2666 aswell
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543258
What speed is it currently at? Sorry if you’ve said before and I’ve missed that.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543277
Are you entering the timings or using XMP profile?
You should try XMP profile first, just set it to on/xmp and then select the speed you want to try.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543387
1 minute ago, Entonite said:
i couldent Find XMP in my Bios
photo of your advanced options please?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543394
Oh, sorry I forgot it's different on Asus BIOS/UEFI, I think it's either manual or tweaker then.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543473
i found some Profile i cant rememver the same of D.O.C.P. or something it seems to have boosted clock speeds but CPUZ shows not 2666
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543508
Pics?, I don't have that board or bios, so can't see what you are seeing.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543525
Ok, had a quick google, apparently XMP can even be seen in EZ mode. It says like "XMP - disabled" approx half way down. Set that to enabled/profile/  then more options come up that you can set to 2666 for example.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/845185-am4-ram-speed-issues/#findComment-10543547
