VGA Resolution.
Go to solution Solved by EthanCoow,
3 minutes ago, Nosfy said:
Hey guys.
So I got a new laptop at work (a generic Dell) which has no HDMI or DVI connections.
All it has is a VGA port. Is there a maximum resolution this can put out? I wanted to get a 1440 ultrawide monitor to connect to it for better productivity.
Thanks.
I don't think it will work with an ultrawide monitor. All of them require a least an HDMI connection to work. Besides, VGA is a analog signal, you would not want to use it with higher resolution monitors anyway, it looks bad.
Hey guys.
Thanks.
CPU - i7 8700K / Motherboard - ROG Strix Z370 E/ RAM - 32GB Cosair Vengeance DDR / GPU  - GTX 1080ti - EVGA FTW3 / PSU - Seasonic Snow Silent 750W / Cooling - Cryorig H7 Monitor - Acer X34 Predator / Sound - Corsair Void - Case - Meshify C
https://linustechtips.com/topic/845156-vga-resolution/
Hey guys.
Thanks.
https://linustechtips.com/topic/845156-vga-resolution/#findComment-10542984
Quote
The same VGA cable can be used with a variety of supported VGA resolutions, ranging from 640×350px @70 Hz (24 MHz of signal bandwidth) to 1280×1024px (SXGA) @85 Hz (160 MHz) and up to 2048×1536px (QXGA) @85 Hz (388 MHz). There are no standards defining the quality required for each resolution but higher-quality cables typically contain coaxial wiring and insulation that make them thicker. Shorter VGA cables are less likely to introduce significant signal degradation.
https://linustechtips.com/topic/845156-vga-resolution/#findComment-10542989
