Got another 540 today for my spare part build. Really didn't wonna buy something else. Guess it a no-go on the Monsta rad on the back panel. Wanting to have all the rads on the back this time. Thinking 420 worth would suffice the build. Prolly get an ek 280 and see how it goes.
https://linustechtips.com/topic/845043-air-540-custom-cooling/
9 minutes ago, Mick Naughty said:
else.
Have fun!
Presumably you are going to have a motherboard there, so is the fan actually going to be doing something? or is it just to mount the radiator?
https://linustechtips.com/topic/845043-air-540-custom-cooling/#findComment-10541592
Well both rads would indeed have fans. Just done wonna go through all the work with such little clearance. Cable management would have to be perfect.
https://linustechtips.com/topic/845043-air-540-custom-cooling/#findComment-10541639
