Hey guys, can anyone recommend me some good case fans from amazon.co.uk? They must be silent and inexpensive. I was looking at the Arctic F12 PWM as they have a female 4-pin fan connector coming out of the male connector, meaning you can connect more than one fan in the same header without buying a splitter.
Many thanks, Bruno.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/844968-case-fans/
Noctua's pwm
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
https://linustechtips.com/topic/844968-case-fans/#findComment-10540752
Just now, PETRGangKing said:
Noctua's pwm
The Noctua fans are expensive. One fan is about £20. I was looking to spend around £5.
https://linustechtips.com/topic/844968-case-fans/#findComment-10540761
I've got a Fractal Design Silent R3 as my exhaust fan and it's pretty quiet. Airflow isn't phenomenal, but it's decent as an exhaust fan. For intake fans, I'd honestly spend a little more. I spent £15 on a Noctua Redux fan and it's miles better than any other fan in my system. Admittedly it's like a jet at full whack, but you only need to run it at 50% speed or below to get ample airflow out of it, making it almost silent.
Gaming PC: i5 8600k @ 4.8GHz | 16GB T-Force Delta RGB @ 3200Mhz | Asus Prime Z370-A | Sapphire Radeon VII (Dead :( ), RX480 8GB | EVGA SuperNova 750 G2 | 120GB Sandisk SSD Plus, 120GB Kingston A400 | 4TB Seagate 7200RPM , 1TB WD Blue 7200RPM | Phanteks P400 Windows 10, MacOS Catalina
Second PC: i5 3340s @ 2.8GHz | 8GB Corsair Vengeance @ 1333MHz | EVGA 750Ti SC | Cheap £7 250GB WD HDD Windows 7
LaptopLate 2009 MacBook (Core 2 Duo, 4GB Ram, 120GB SSD, 9400m, running Mojave) , Late 2013 MacBook Pro Retina (i5, 4GB Ram, 128GB SSD)
Consoles: Xbox One, PS4 Slim, PS3 slim, Xbox 360 fat still going strong after almost 10 years, Original Xbox, PS2, PS1
Phone: Realme 6, Xiaomi Mi A2, Xiaomi Redmi Note 4x, iPhone 6s (jailbroken)
Tablet: iPad Mini 2nd Gen Retina (Jailbroken)
Headphones:  Hifiman HE4xx, Phillips Fidelio X2, Status Audio CB-1,  Fiio E10k DAC, Schiit Magni 3+, Tin T2 IEM's, Astrotec S80
Keyboards:  2x Custom 60% - 1x Gateron Yellow, 1x Box Reds
https://linustechtips.com/topic/844968-case-fans/#findComment-10540811
pfft hahahaha! would you like to eat your cake too?!
you can barely get shitty case fans for 5!
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/844968-case-fans/#findComment-10540814
7 minutes ago, kb5zue said:
LOL, not true.  I got shitty fans for less than 5 at the local recycle.
LOL in that case i can get some free ones out of dumpster at the hospital.
System specs:
https://linustechtips.com/topic/844968-case-fans/#findComment-10540909
I have a higher budget than this, but it seems a bit too much for a couple fans. I might go for be quiet fans.
https://linustechtips.com/topic/844968-case-fans/#findComment-10540991
