I turned on my computer today and noticed 8gb of my 16gb were "hardware reserved." I noticed in my UEFI settings it says single channel memory mode (picture provided). I'm not sure if this is related to the problem, but i can't understand what any of the settings in the UEFI mean. I also saw some people mention it was windows causing the problem, but none of the fixes i found worked.20171010_141922.thumb.jpg.e6697dd0a755c7c2d0374d5f3312b1ba.jpg59dd2013557eb_untitled(2).thumb.png.95e2e0f7b384c7f8adad5707b5ef474a.png
https://linustechtips.com/topic/844957-hardware-reserved-issue/
Usually this points to a failed or about to fail stick of RAM. Remove one stick at a time and see which one is bad. Use Memtest86 to confirm.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/844957-hardware-reserved-issue/#findComment-10540624
Turns out one of my sticks are bad. What can cause this? The RAM is only 2 months old and it was just working yesterday
https://linustechtips.com/topic/844957-hardware-reserved-issue/#findComment-10540706
It happens. Not very often, but anything can fail at a moment's notice really.
https://linustechtips.com/topic/844957-hardware-reserved-issue/#findComment-10540737
