Yes it is somewhat normal when the game engine can't use the full extension of the CPU, you should download MSi Afterburner to see your GPU usages with a GPU stressing software like Heaven Benchmark to see if it reaches 99%
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/844869-gpu-cpu-usage-issue/#findComment-10539603
Tried that, that's why i was concerned about it , because it did it on 960 aswell, so i thought that gtx 960 is just too slow for this cpu
https://linustechtips.com/topic/844869-gpu-cpu-usage-issue/#findComment-10539609
You could always DDU in safe mode and reinstall the drivers fresh new.
Personal Desktop":
https://linustechtips.com/topic/844869-gpu-cpu-usage-issue/#findComment-10539615
Well, I'm planning to reinstall my whole system, since it's easy on SSD... i think there is some mining viruses and some shizwaz on my pc, because in Precision XOC , the gpu is pegged on Base clock of GPU and even the VRAM...
https://linustechtips.com/topic/844869-gpu-cpu-usage-issue/#findComment-10539634
