need to get a controller
By
Glennieboyyy007
in Peripherals
in Peripherals
Solved by zxsq,
Xbox One controller is non rechargable, no cable included. It will work on windows 10 in 2 different modes: connected with microusb cable it has audio passthrough to the controller's 3.5mm port. Connected over bluetooth, it does not.
With the xbox one controllera, the microsoft dongle is only required for wireless audio passthrough, or multiple controllers.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases6 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
