I bought Call of duty 4 yesterday and tried to play. I get an error message saying "failed to initialise punk buster, punk buster is disabled"
Please help :(
https://linustechtips.com/topic/844011-issue-with-cod4/
The issue is you're playing COD4 :P
Punkbuster is an old anti-cheat system, not sure if it still works anymore on modern hardware.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530680
Seriously? wasted £10 on a game that I can't even play. ffs.
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530683
Try to download it directly:
https://www.evenbalance.com/downloads.php
Prior Build Log/PC:
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530685
I did.. Installed it and I can't add the game..
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530689
I still play Cod4 from time to time. First of all disable Punkbuster in Options. It doesn't work for years. Secondly play on custom servers, which you can find on Gametracker.com or similar. There's a pretty solid playerbase and you won't find any kids or annoying russians (mostly). To connect to a server press ~, then type /connect (Copy/paste Server IP)
This works on most servers
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530702
CBA. I requested a refund...
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10530708
I bought it on Friday, and played it on weekend without any issues.
When running 1st time, it was stuck while installing punkbuster or doing something about punkbuster. I closed the message, started game again, and it worked for me.
Finally got PS4 Pro
https://linustechtips.com/topic/844011-issue-with-cod4/#findComment-10536488
