Low noise adapter + PWM?
Solved by manikyath,
Just now, Cinnabar Sonar said:Fans have a minimum RPM correct? I was wondering if that minimum could get lower with a low noise adapter.
well.. in case of PWM, minimum RPM would be the PWM pin tied to ground, which if you bought some quality fans is either off, or so slow that you couldnt possibly want less.
Featured Topics
Mistr J ·
Posted in Troubleshooting2 -
Gecko ·
Posted in General Discussion0 -
1
4
2
coolbean28 ·
Posted in Graphics Cards8 -
awsomename999 ·
Posted in Troubleshooting4 -
RoyTheGeek ·
Posted in Phones and Tablets2 -
NexDeformedpoto ·
Posted in Networking2 -
5
