Hey guys, i just want to cry because im angry and frustrated.
So, i need help :/
There is my config ;
Asus rog strix blablabla 370-f gaming(the special amd one)
Ryzen 7 1800x
x62 krakren(aio)
4x8go gskill tridentz rgb 3200mhz
1080ti strix
So, i've led orange on my motherboard wich means that i've a problem with DRAM.
I've tryed all the slot with all the ram and nothing at all.
My pc start but i've no display on monitor and peripherals wont work.
I've tryed to move out the battery of the mobo, nothing too..
Best of all, ive already installed win 10 on the PC, he was working before i tryed to get more ram on the PC(it was working with 16go before)
Now, even if i install only one ram, its still the same problem, this ****** orange led.  Same with 2 ram, 3 ram, 4 ram.
Seems like my motherboard is broken or  the rams, but i dont understand why it was working before and not now. Everything is new.
Can you help me ?
https://linustechtips.com/topic/843763-orange-led-solid-on-my-mobo/
Are you referring to the light above your ram or on the bottom right side of your board?
Clear CMOS?
Check PSU?
Check DRAM Voltage?
CPU Voltage?
Try booting with Ram at 2400 Mhz?
Steam Profile
AMD Ryzen 7 1700X, 3800 MHz (38.00 x 100)  /Offset + v 0.018
Asus Hero VI Motherboard
NZXT Kraken X62
G Skill F4-3200C14-8GFX  O.C. 3200 MHZ (14-14-14-28 ) x 2   1.4 v
NVIDIA GeForce GTX 1080 SC2  (8 GB)
27 Dell 2K 144 Hz G sync display
Hello, on the bottom right of my mobo(its also above the ram because my ram is on the bottom right of my mobo aswell).
Check my PSU ? Its a seasonic 650w 80gold+
I cant really tell you how much voltage my CPU is but its 3.6Mhz
DRAM voltage is 1.35v
I'm not really expert, but by clear CMOS you mean touching the pin with a screwdriver ?
And yeah, i cant boot anymore(even with only one ram on any slot) :/ My PC turn on but no display on monitor and peripherals not working.
It was also the case when i downloaded a game or update, my pc was still working but my monitor shutdown(no display) and my peripherals too, all i can do was rebooting the PC.
Thanks.
I would not think your ram is bad because you have multiple sticks to test with.
I would contact ASUS support and see if they could help you troubleshoot.
And if that does not work began the return on the motherboard.
Steam Profile
NZXT Kraken X62
Hello, i got fresh news.
Im dumb..  Well, if it can help other people dont forget to push the ram nicely and dont be scared.
In fact, i have pushed all the memory in the slot and when i heared the "click" i was thinking that the ram was correctly in the slot.  I was wrong.
I have to push all the way up and down to hear two clicks, LOL!
So, my pc recognize 32go now, im happy with that but i still have the same problem.  When i update my game "Blade and soul" all of my peripherals shut down and my monitor say "no display" .  Btw, i just play PUBG on the PC, everything went fine, so i dont really understand ...
Can you help me with that ?
And sorry, my english is not perfect at all, i try my best to be understanded here
If it can help you https://imgur.com/a/NExIw
5 hours ago, pokeroas said:
It just doing the same problem again when i was playing PUBG.
Everything shut down expect the PC.  I thinks its a overclocking problem, dont you think ?
I think you just answered you own question.    The purpose of resetting CMOS is to put all settings at stock.
I'm not sure if the Asus rog strix blablabla 370-f gaming(the special amd one) has a Q code when this happens.?
Also updating the motherboard bios has fixed my Memory issues.
Your CPU seems warm for only using 1%.  Have you  tried a  stress test like AIDA64 to check temps under full load?
Steam Profile
NZXT Kraken X62
All the system was overcloacked, i fixed that with a cmos.
All the temp is fine now.  I have only one bug and its this Qled orange blinking now, not solid anymore.  I dont understand the problem, it happen when i play a game or download sth.
