I have been using the laptop for past 2 yrs- HP Pavillion ab220tx
gotten green light for the build
this is what I have in mind for my build
https://in.pcpartpicker.com/list/RksZVY
THIS PC WOULD SOLELY FOR GAMING.
AMD - Ryzen 5 1600 3.2GHz 6-Core Processor
MSI - GeForce GTX 1070 8GB Video Card
Asus - STRIX B350-F GAMING ATX AM4
Cooler Master - MasterLiquid Lite 120 66.7 CFM Liquid CPU Cooler
G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory Seagate -
Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
samsung ssd250gb
Phanteks - ECLIPSE P400S TEMPERED GLASS ATX Mid Tower Case
EVGA - SuperNOVA G2 750W 80+ Gold Certified Fully-Modular ATX Power Supply
minimum wattage- around 550
QUESTIONS -
1. would you recommend any other cabinet or phanteks eclipse400s good enough?(around 80$)
2. suggestions for a monitor around 200$
3. CPU cooler recommendation
4. any changes you would make if this was your build
5. criticize the build
every builder name their build Build Name-
"IDIOT BOX"
thank you
https://linustechtips.com/topic/843544-my-very-first-pc-build/
ok ryzen runs cool, no need for a costly AIO, a hyper 212 or cryorig h7 would have done good. next a 750w psu is to0 much of an overkill for your specs a 550w would be good, but get an evga 650g-series psu if you can. There is this slightly old but good gaming monitor, the acer gn246hl, it has a tn panel, 1ms response time, and 144hz refresh rate so this monitor is good for gaming within that $200 budget.
https://linustechtips.com/topic/843544-my-very-first-pc-build/#findComment-10526036
Are you by any chance from india, because of that in.pcpartpicker
4 hours ago, overlord000 said:
That p400s case costs $200 in your country, that case normally costs $80 you are buying it for $200? omg.
don't get that master liquid cooler, if you get ryzen a hyper 212 in your region would cost lesser and cool good too. do you really want to pay $50 more for that rgb ram instead of some vengeance lpx. Google this case - cooler master masterbox lite 5 rgb, it is officially a gaming case as said by cooler master, it has 4 fans for high airflow too. High airflow reminds me of the cooler that releases in 3 days, the h500p it is awesome and if it comes to your country it should cost the same as the phanteks one but will be a billion times better. Or else get the mastercase pro 5 which is the same price as the p400s in your country. An msi gtx 1070 costs the same as a zotac gtx 1080 mini in your region, it is obvious which would be better...
https://linustechtips.com/topic/843544-my-very-first-pc-build/#findComment-10526081
Get an i5 8400 and any Z370 mobo. Run stock cooler or any cheap cooler(not a 212 EVO tho). Don't spend that much on RAM, that's over 50% more than you need to pay for 16GB RAM. Drop the PSU to any decent 450W to 550W unit.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/843544-my-very-first-pc-build/#findComment-10526264
yes I know it cost 200$ in my country but I'm (was) buying it from NewEgg which cost  67$ +free shipping
 I would be sure to check out cooler master -master box 5 (loved it, thanks)
not getting that liquid cooler-- folks at Reddit said that even the stock good for the CPU (your thoughts???)
MasterCase H500P ---- damn that looks sexy (not getting one)
MSI GeForce GTX 1080 DirectX 12 GTX 1080 ARMOR 8G OC 8GB 256-Bit GDDR5X ( found this 1080 while searching for
 ZOTAC gtx 1080 mini)  (50$ cheaper than mini) should I go for MSI one then????
https://linustechtips.com/topic/843544-my-very-first-pc-build/#findComment-10530598
1
even I thought that PSU would be overkill. will be sure to buy 550w.
CORSAIR Vengeance LPX 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200- would this be the ram you would recommend????
I never thought of an intel build cause of the ryzen launch but after seeing the comparing the two i have to thinks about it but mostly I'm leaning toward the ryzen side.
https://linustechtips.com/topic/843544-my-very-first-pc-build/#findComment-10530652
