CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($279.00 @ PCCaseGear)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($199.00 @ PCCaseGear)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($185.90 @ Newegg Australia) actual price $169
Storage: Transcend - 240GB 2.5" Solid State Drive  ($105.00 @ Umart)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($60.00 @ Shopping Express)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($360.80 @ Newegg Australia) actual price $328
Case: Deepcool - D-Shield ATX Mid Tower Case  ($49.00 @ Scorptec)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($75.00 @ Shopping Express)
Monitor: LG - 25UM58 25.0" 2560x1080 75Hz Monitor  ($219.00 @ Kogan)
Total: $1532.70
Generated by PCPartPicker 2017-10-06 22:46 AEDT+1100
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522442
Total: $1532.70
Thanks a lot, I really do appreciate it.
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522451
I know it's not a list, but I don't have time right now. Maybe later.
Get a Ryzen 5 1600 and a 1060. If you can squeeze in a 1070, get that. Don't forget high clocked memory either.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522468
Honestly, if your friend is looking at just gaming, a ryzen 3 1200 will perform the same as a ryzen 5 1600 or slightly lower than an i5. you can use the saved money to get a gtx 1070, which u will get MUCH more frames than with a 1060 6gb.
just remember to overclock the cpu, if you are not comfortable with that, go with the 1300x for $30 more.
here is the ryzen 1300x and gtx 1070 playing games at 1080p ultra (as you can see, good performance)
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($138.00 @ Shopping Express)
Motherboard: ASRock - AB350M-HDV Micro ATX AM4 Motherboard  ($88.00 @ Shopping Express)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive  ($119.00 @ Shopping Express)
Video Card: GALAX - GeForce GTX 1070 8GB EX Video Card  ($585.00 @ Scorptec)
Case: Deepcool - Frame MicroATX Mid Tower Case  ($39.00 @ Scorptec)
Power Supply: Silverstone - 500W 80+ Bronze Certified ATX Power Supply  ($49.00 @ Umart)
Total: $1482.90
Generated by PCPartPicker 2017-10-06 23:10 AEDT+1100
if you have a preference for a particular design for the graphics card, you can go with the following options for $5 more:
MSI GTX 1070 DUKE OC
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522484
Total: $1482.90
the ryzen 3 will bottleneck the gtx 1070 and the psu is low quality.
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522489
welp, you still get more fps with 1300x+1070 than the i5 8400+1060 for the same price.
as for the psu, you can upgrade it to the one you suggested if u want, although that psu is tier 6 and I have owned 4 tier 7 psus powering similar systems with no issues
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522492
just because you have a few bad quality units that work doesn't mean they should be used.
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522501
yes I understand and I have felt the wraith of it (losing 5TB of hard drives to a junk psu) but that is a true 7 year old $5 psu. psus tier 6 and above should be fine, although tier 4 and above is ideal
https://linustechtips.com/topic/843161-help-building-a-pc/#findComment-10522508
