I have an H100i v2 on it, I'm just unfamiliar with overclocking on Ryzen. Any guides out there that you have found particularly helpful when it comes to overclocking on AMD?
CPU: Ryzen 7 1800X
CPU Cooler: H100i V2
RAM: Trident Z RGB 16GB 3000MHz Cl 14
Motherboard: ASUS RIG Crosshair VI Hero AM4 ATX motherboard
GPU: 980Ti
PSU: Rm1000x
Storage: Samsung PM961 512 GB m.2 Nvme sad
Storage: 7500 RPM 2 TB Seagate Barracuda Hard drive
Case: 570X RGB (White)
OS: Windows 10 Pro
https://linustechtips.com/topic/843147-help-with-overclocking-1800x/
Most of the techtubers on youtube have many pretty good guides, follow those to get familiar, that look at actual extreme overclocker guides, to understand it all. You probaby won't be able to use the same kind of voltages as those guys though, but they explain what they all mean and you can get a little more out of normal overclocking knowing the extreme stuff. Even though it's air cooled I got my GTX 980 to 1580MHz following the principles of extreme overclocking.
Yours faithfully
your mobo supports easy overclocking
most of the time you just punch the multiplier that you want like 40 x 100MHz
put like a maximum of 1.37 volts and set the RAM speed to 2933Mhz and save the settings
if the OC fails you just go back into BIOS and try a lower value or pump more voltages
1800X should easily hit 4GHz and in some cases hit 4.1 or 4.2GHz if you are really lucky with your silicon lottery
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Overclock your cpu first then your ram only after you maintain a stable overclock should you adjust your ram and timings
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
